time delay circuit/component
hello, I need help.
In my circuit I have a square wave output and need to delay it by 10ns. Do you have any idea how could I do that?
thank you very much
thank you very much
RE: time delay circuit/component
<nbucska@pcperipherals.com>
And also how much distortion of the input signal is allowed. All circuits change their inputs to some extent, although plain resistors don't change the shape much.
Assuming your square wave comes from a logic circuit, the best solution I have found is to use one or more non-inverting buffers, or an even number of inverting gates, to get the desired delay. This is usually quite stable with temperature, but does tend to vary slightly from board to board, depending on the individual logic chips. If you really need to get the delay consistent between units, this can be arranged by having a "select on test" tapped chain of gates.
