How to use the LMATRIX Command ?
Hello, i´m trying to use the LMATRIX command cause i want to calculate the mutual inductance betwwen two simple coils, but there is one error that sais : "The condictions for direct assembly have not been met. The following magnetic elements support direct assembly: 36,..... Use frontal solver (ESLV, front command) to obtain operating solution before computing inductance by the LMATRIX command macro". I have tried to make this but i do not why, it does not work, so i will be happy if someone can help me. Sure...
Thanks. Martin (Spain)
