matlab workspace
matlab workspace
matlab workspace
How can I print a matrix from matlab workspace note(print,copy,paste,cut)inactive command in my window?
RE: matlab workspace
I'm not sure what you mean? Are you saying that you want to print out a matrix but you can't cut or copy from the command window? If this is the case then you can save the matrix as an ASCII text file and import it into a spreadsheet such as Excel where you can easily print it out.
use the command
save my_text_file.txt my_matrix -ASCII
M
