curve parameters
curve parameters
Hello All,
I have not been able to view the dialog bar when creating and editing arcs. This is the first time I have had to do this since loading NX 1.0.1.2. Did the dialog box move somewhere other than where it was previously? I am used to seeing it appear in the lower right corner of my screen, but now, instead of the usual dialog bar, I get a statement of how the curve is/was created, i.e. screen position. Any help would be greatly appreciated. Thanks!
EWH
EWH
RE: curve parameters
Does this toolbar have a name because I can't seem to find it while customizing my toolbars.
Michael
Edit the Curve as you normally would, and when you expect the input parameters toolbar to show, choose the following: View > Toolbars > Customize > Close;
the toolbar should now display.
I'm not sure if this will help you with your problem. Good luck!
Eric
Do you have a word document somewhere with UG workarounds, I'm thinking of creating one for myself?
I seem to use them a lot.
Michael
