Suppress view
Suppress view
Suppress view
Is there any way to suppress a drafting view?? Or to have the view auto delete depending on expressions?
RE: Suppress view
If it helps you can set the view to "reference"
RE: Suppress view
What I'm trying to accomplish is to create a spreadsheet driven part that will create a drawing that needs minimal "fine tuning". There is an instance where there is a section needed to show details of a feature that may or may not be on the part. If it is not on the part I would like the view to suppress or delete.
RE: Suppress view
Understand you better now, I haven´t tried to accomplish that yet, but I haven´t heard about supressing or deleting views per automatic. I wpuld suggest a layer move and use visible in view on the drafting views, you would then get a blank view.
RE: Suppress view
I have considered accomplishing it through visible in view. Can visible in view be controled by expression?
RE: Suppress view
If think I now remember that you actually can supress drafting object if you set environment variable UGII_DRAFT_EXPRESSIONS_OK=1 and then you can access the expressions through drafting. But this setting is not recommended due to you actually can control the modell through drafting.
About visible in view, I was actually thinking that the solid layer should be controlled not the view
RE: Suppress view
UGII_DRAFT_EXPRESSIONS_OK = 1 only allows you to the Tools-Expression dialog box while in drafting mode. It allows you to modify model expressions from drafting.
Drafting section views are not subject to layer viv easily. The section lines are created as view dependent to a system generated view and placed on the current work layer. You would have to be very careful when creating the view to get everything set right for it to work.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: Suppress view
Activating expressions in drafting gives you the ability to suppress drafting objects with expressions, such as annotations, dimensions and notes.
