wet basement
wet basement
Help. We are adding a two story addition, with a walk out basement apartment. The foundation is near a 38 foot dug well.We have tarred the blocks, put in perforated pipe covered with stone.The outside wall is still exposed. I see a wet spot, four foot square, on the inside block, around 4 to 6 feet below ground level. After two dry days, the surrounding soil and stones are dry, but a four foot wide patch of soil and stones are damp. What can/ should I do before I must continue the construction?
Thanx, Noemi
Thanx, Noemi
RE: wet basement
Brian
RE: wet basement
RE: wet basement
RE: wet basement
The truth will set you free. Best of luck. Geodude
