Manipulating framed checkboxes on Access forms
While working on an access database I discovered that it is possible for a dropdown list to contain values returned by a query. I also noticed that this is not possible for a frame with checkboxes, although i need that.
Thinking off solutions I thought it might be possible to modify the control, made before hand with the Userform_Load routine like the way it is possible in other office applications (if I remember correctly) using a dim/set as Control satatements. I have been looking through the help available in Access but cannot find a way to tackle the problem. Also on the internet I have not been able to find a possible way/solution.
Can somebody give me a hint or guide to a possible solution for adding options in a checkbox frame to a form?
Thanks in advance!
