CORRECTED TURBINE GAS HEAT RATE
I work an electric power plant in Panama City. We have a LM 6000 GE Turbine that produce 48.2 MW. I have the code of Asme that explains how to calculate the heat rate and I have the guarantee values that GE did at first year of operations. These values were corrected using 82°F To, 85% HR, 14.7 psia Po. They used a particular graphics to do it but I have a problem becasue the National dispach Center of Panama wants tha I calcule the corrections using other values for example 83°F and 90%HR. I need informations about how calculate these graphics or any book or site on internet that has this information.
Best regard,
Juan Aguilar
I&C
Copesa Power Plant
Republic of Panama
Email.: jdaguilarc@hotmail.com
Phones: (507) 200-1045
Best regard,
Juan Aguilar
I&C
Copesa Power Plant
Republic of Panama
RE: CORRECTED TURBINE GAS HEAT RATE
Hope this helps.
thanks. I have PTC- of ASME that indicate this informations, but I dont understant stadistic method. Can you help me in this?
tanks,
juan
I just finished a spreadsheet that contains the GE curves for a 7EA. It includes the corrections on one sheet, and a figure of the curves on another. The figures include the design point and the measured point.
This is my first time visiting eng-tips.com. I don't see how to send an attachment to you.
If you send your email address to LPenna@MDAturbines.com, I will be glad to email it to you. Or if you email the curves, I will create the corrections for you, no charge.
Lon Penna
The Test Engineer
Member ASME PTC-22 (gas turbines).
