Configuration of Pro-E
I'm fairly new to Pro-E and have a few questions regarding its configuration. How do I configure it so the model comes up solid instead of wire frame? How do I set it so all datum’s are turned off when I open a file for the first time? How do I set the view performance to default to the settings I want? I've looked in the config.pro and can't find the controls for these settings. Any help would be greatly appreciated.
RE: Configuration of Pro-E
To control startup mode of display options...
DATUM_DISPLAY (yes),no
AXIS_DISPLAY (yes),no
DISPLAY_COORDINATE_SYS (yes),no
To set startup display mode for part/assy...
DISPLAY (wireframe),hiddenvis,hiddeninvis,shade
To adjust view performance through config...
FRAMES_PER_SECOND (yes),no
FRAMES_PER_SECOND_VALUE (3)
These settings came from 2000i2 config, but since they are basic settings, I would imagine they are identical to 2000i.
Also, if you can get your hands on the Pro/E 2000i2 documentation CD, you will find a host of .pdf files comprising a comprehensive manual. One of these files contains ALL config options available for 2000i2. I found it pretty handy to just copy the directories of .pdf files to my local hard drive for quick reference.
Spencer
