part intelligence
part intelligence
Hi
im trying to put partial intelligence on a simple part that is a 4in sq and 1in thick block. The block has .5 radius fillet,and a hole of 1in diameter on each corner.The problem is that i dont know the formula for keeping the hole on the same distance with the part when i change the demensions.
RE: part intelligence
Take a look at
http://members.rogers.com/puk/formula.jpg
It keeps the hole at .175in from part sides.
To display "Parameters & Relations" go to:
Tools/Options/General/Parameters/Knowledge--
check "With Value" & "With Formula"
Tools/Options/Infrastructure/Product Structure/
Specification tree
check "Parameters" & "Relations"
Hope this will point you in the right direction.
Puk
