Which software to use for scheduling?
Qualificatons
1) Appropriate for scheduling jobs in a machine shop.
2) Relatively easy to use
3) Relatively inexpensive (I looked at Esti-Track from Henning; wow - $7000 is way too much!)
4) Ability to see schedule graphically by Bar or Gannt charts.
5) Used by many companies. This says two things: the sotware and its maker will probably be around for years, and it is a decent product because it has captured a good market share.
Thanks for any help! -- wcarey
RE: Which software to use for scheduling?
http://www.trilogydesign.com
Might be of some use to you worth a look !!
GOOD LUCK!
http://www.alberts.com/authorpages/00013310/prod_48.htm
http://www.softtreetech.com/24x7/screen_shots.htm
If on the other hand you need to do job scheduling for maintenance personnel and keep reconds of your equipment and all of that sort of stuff then I would recommend you look at Datastream's product called MP2. We used it at a facility in which I worked and they are pretty good with their service. You can see them at:
http://www.datastream.net/
Hope this can help you out in some way and you have a GREAT day.
http://www.dbasoftware.com/products.html
They advertise that they are #1 in software for manufacturing and job shops and a single user system is less than $500. The software can also support multiple users over a network. Tell them who sent you if you buy!
Dave Butcher
President
B Machine Products
Parkersburg, WV
http://BMachineProducts.com
