Macro for reading point locations
Does anyone have a macro laying around that would query the xyz coordinates of points in a 3d sketch and save them to a .txt or .csv file?
If you do I surely would appreciate a copy!
Jon
jgbena@yahoo.com
RE: Macro for reading point locations
instructions:
select the sketch that you wish to "read" and run the macro.
the macro will bring up excel and start filling the sheet with xyz point data.
Sub main()
Dim swApp As SldWorks.SldWorks
Dim doc As SldWorks.ModelDoc2
Dim part As SldWorks.PartDoc
Dim sm As SldWorks.SelectionMgr
Dim feat As SldWorks.feature
Dim sketch As SldWorks.sketch
Dim v As Variant
Dim i As Long
Dim sseg As SldWorks.SketchSegment
Dim sline As SldWorks.SketchLine
Dim sp As SldWorks.SketchPoint
Dim ep As SldWorks.SketchPoint
Dim s As String
Dim exApp As Excel.Application
Dim sheet As Excel.Worksheet
Set exApp = New Excel.Application
If Not exApp Is Nothing Then
exApp.Visible = True
exApp.Workbooks.Add
Set sheet = exApp.ActiveSheet
If Not sheet Is Nothing Then
sheet.Cells(1, 2).Value = "X"
sheet.Cells(1, 3).Value = "Y"
sheet.Cells(1, 4).Value = "Z"
End If
End If
End If
Set swApp = GetObject(, "sldworks.application")
If Not swApp Is Nothing Then
Set doc = swApp.ActiveDoc
If Not doc Is Nothing Then
If doc.GetType = swDocPART Then
Set part = doc
Set sm = doc.SelectionManager
If Not part Is Nothing And Not sm Is Nothing Then
If sm.GetSelectedObjectType2(1) = swSelSKETCHES Then
Set feat = sm.GetSelectedObject4(1)
Set sketch = feat.GetSpecificFeature
If Not sketch Is Nothing Then
v = sketch.GetSketchPoints
For i = LBound(v) To UBound(v)
Set sp = v(i)
If Not sp Is Nothing And Not sheet Is Nothing And Not exApp Is Nothing Then
'sheet.Cells(2 + i, 1).Value = "Normal Vector " & i + 1
sheet.Cells(2 + i, 2).Value = Round(sp.x * 1000 / 25.4, DEC)
sheet.Cells(2 + i, 3).Value = Round(sp.y * 1000 / 25.4, DEC)
sheet.Cells(2 + i, 4).Value = Round(sp.z * 1000 / 25.4, DEC)
exApp.Columns.AutoFit
End If
Next i
End If
End If
End If
End If
End If
End If
End Sub
Jon
jgbena@yahoo.com
Paul
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Would you mind posting your macro on the FAQ section. I have a spreedsheet that spits out x & y points for gerotor geometry and want to read it into SWx. My current MCAD program is Pro/e but I want to hone my SWx skills thks
"Never underestimate the power of very stupid people in large groups." John Kenneth Galbraith
Scott Baugh, CSWP
FAQ731-376
by
sheet.Cells(2 + i, 2).Value = sp.x * 1000
And thanks Scott ;)
Jon
jgbena@yahoo.com
