Dell 330 Nvidia Quadro 2 Pro
We are have trouble with an Nvidia Quadro 2 Pro, Win NT 4,  SP6, 2000i. When zooming into a model axis tags enlarge in size. Also in drawing mode our title block and tables seem to separate from the rest of the drawing. This could be a driver problem but have found numerous drivers available. If anybody knows the correct  driver for this configuration I would appreciate your help.
Thanks in advance.
RE: Dell 330 Nvidia Quadro 2 Pro
The title block floating away in the format happens on my HP Kayak so I don't think it is hardware specific. I'm running 2000i build 2000050.
If you remove the format a put it back on again the floating seems to go away.
I had the same problem on two Dell 330's.  One ran NT, the other W2000.  Download the correct drivers from the Dell website to fix the problem.
I had the same problem on my 330. The latest Detonator3 driver from Nvidia's site solved all problems.
 Note: If you decide to download the driver, use the FTP download and not HTTP. They are supposed to be the same, but I have heard of problems with the HTTP download.
Yep! Drivers fixed it.
Thanks for responding
