Crack Control in Structural Slab - Flat Plate at Ground Level
What does ACI or PCA recommend for keeping cracking at absolute minimum in a structural slab?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Crack Control in Structural Slab - Flat Plate at Ground Level
ARIF ALI SIDDIQUI
STRUCTURAL DESIGN ENGINEER
IMCC 8 JANTAR MANTAR MARG
NEW DELHI INDIA
See the relevant chapters in BS8110 (concrete) and BS8007 (water retaining structures).
Also you can download Excel spreadsheets which contain crack calculation software amongst many others (www.structural-engineering.fs.net.co.uk and www.rcc-info.org.uk)
For general R.C structures, we adopt 0.3mm maximum width while for water retaining structures 0.1mm and 0.2mm may be used as the limiting value, depending on the importance of the structure/finishes etc.
