Sour Gas Absorption Column Design
Hi,  I am in the process of designing a acid gas removal system for petroleum plant. I was wondering where i might find the latest equilibrium data for absorption of H2S in DEA; and or Absorption Column design for a countercurrent, bubbletray, H2S/DEA gas sweetening absorber?
RE: Sour Gas Absorption Column Design
This is a complicated subject. Even the choice of amine or other sweetening system requires a detailed study of the  gas to be sweetened, the operating conditions, the sweet gas specifications, the ambient conditions, the environmental standards and the utilities available.
If you need a consultant to help you with this process, contact me.
G. Gordon Stewart, P.Eng.
Gas & Oil Process Engineering Consultant
http://www.ggordonstewart.com/
ggstewar@telusplanet.net
Even I am in a dire need of such designing procedure and data, if you find it can you pl. let me know of the same. as for the DEA-H2S system you can approximate it using MEA-H2s system, the data for which are present in the latest edition of Perry's handbook for chemical engineers.
my e-mail add. is savvy13@rediffmail.com
You can use DESIGN II for Windows at www.winsim.com to design sour gas columns using single / mixed amine for H2S / CO2 removal.
Lynn McGuire
winsim@winsim.com
Huntsman chemicals has a program to give a rough estimate, the use WinSim to get the detailed answer.
http://www.huntsman.com/?show=home
