does any body know how you import
does any body know how you import a reference image (jpg or bmp) into AutoCad, so that it can be used as a guide for creating the drawing.
RE: does any body know how you import
I think you can resize or scale a raster image only. If you need use snaping to image's objects, imported *.wmf lets to do it.
If you just need the basics of importing, go to INSERT >> RASTER IMAGE or you can do a copy and paste into your drawing. You can then rescale the image to the size you need.
Dude,
BorgUnit is right ...
Just to add to that note ...
Make sure ...
imageframe=on
If this is off, you won't be able to manipulate the iamge.
Hope that helps.
