Are worm gears designed to work in both direction of rotation.
Are worm gears designed to work in both direction of rotation? Or can they be?
We have a conveyor system in a mill with two opposing conveyors belts (opposite direction) coming to a central location to dump their loads in a central location.
These two conveyors are run by separate motor (1/2hp) worm gear outfits. We have a spare that we would like to use for both sides by just reversing motor direction.
input rpm 1750
output rpm 4
Any info would be great.
Etienne
input rpm 1750
output rpm 4
Etienne
RE: Are worm gears designed to work in both direction of rotation.
We are using a Helical-worm gear Unit.
Pekelder
gearguru
In case of helical gearbox depending on the availabilty you can reverse the hand of the gearbox.Care should be taken while fixing the hold back.
Hope this is if of help to you.You can contact FMG for the helical gearbox.
But in multiple starts of Worm gears , Rotation of Both directions are not recommended due to slippage of Load.
In Some Cases Gear boxes having both Helical and Worm Gear pairs having the rotation of Both direction mostly out put shaft mounted with helical Gear Pair.
