Labeling Components on Structural Drawings
When I do rehabilitation of existing structures, I typically title drawings as "rehabilitation" as opposed to "reinforcing" and label components on my drawings as "stiffening" elements. Rehabilitation indicates I am restoring the member or system to its original capacity as opposed to reinforcing which implies that I am giving it additional capacity.
Does anyone have another word for "stiffening" they would use in this vein to label components on one's structural drawings?
VOD
VOD
RE: Labeling Components on Structural Drawings
Thanks for the response, all things considered, there is a lot to think about when one does not want to inherit more liability for a given scope of work.
VOD
Perhaps "restoration" could be an appropriate term. It is usually applied to the exterior of a building, but could as easily be applied to the structure. You are restoring it to it's original capcity (?).
When you "stabilize" a structure, it implies to me halting deterioration. But how do you assess the residual capacity at that point?
Lastly, ASCE has a publication, "Guideline for the Structural Condition Assessment of Existing Buildings", SEI/ASCE 11-99. They provide checklists, discussions and procedures for evaluating existing buildings.
I believe that the word "retrofit" is not quite along the same vein.
VOD
I have heard that several states and major cities have adopted the NJ Rehab Code, but I'm not sure how much it's in use. I can tell you this: it's a fantastic code for getting remodel/repair/rehab work done on existing buildings. The code analysis is pretty straightforward.
