Analogue Time Delay circuit diagram
Hi, I have problem to build and understand the analogue time delay circuit. I need to give an input signal to 3 receivers as a 5 sec time delay is needed for the 2nd and 3rd receivers. What kind of circuit shall I build?
RE: Analogue Time Delay circuit diagram
If you must design a circuit, for us to give answers you need to provide specific information such as:
1)What exactly is the "input signal"?
2)What is it required to do at the receivers? Does it need relay contacts to control the receiver, for example to turn on the power, turn off the squelch or muting circuit, or what?
3)How accurate does the 5 second delay need to be?
4)What power supplies are available to run the delay circuit?
5)What temperature range must it work over?
6)Shielding EMC considerations - are there any high power transmitters nearby?
7)Size, weight, cost?
