calculating flashpoint of 5% (v/v water) isopropyl alcohol
Does anyone know how to calculate the flashpoint of 5% isopropyl alcohol in water? Any help would be appreciated.
RE: calculating flashpoint of 5% (v/v water) isopropyl alcohol
http://www.hc-sc.gc.ca/ehp/ehd/psb/laboratory/c-22.pdf
Data I have for isopropyl alcohol indicates it alone has a flash point of about 12C. I would suspect a 5vol% solution in water would be higher.
You might could find that a supplier produces such a mixture and get the info you need from their MSDS.
Now if you are interested to know if the mixture can produce an explosive atmosphere above the liquid, you could use Raoult's law and Dalton's law to determine the concentration of isopropyl alcohol in the vapor space and compare that to the lower and upper explosive limits for isopropyl alcohol (2%-13%) to see if it is in the combustible range.
Looks like you made a second post while I was composing my first and from your second post I can see your dilema, the flash point for your 5% solution appears to be identical for "pure" IPA.
I don't have detail knowledge of the test methods and that may be where the catch is. Found this link that explains a little more about the test but you may want to get a copy of the ASTM method for full details
http://www.ilpi.com/msds/ref/flashpoint.html
I did find one manufacturer that offers IPA as 50%, 70%, 91% and 99%, their data definitely shows flash point increasing with decreasing %IPA
http://www.cumberlandswan.com/ipa.pdf
But here's another supplier of 50% IPA showing a flash point like "pure" IPA.
http://www.americhemsales.com/MSDS%20HTMLS/9456v0ef.htm
I'm certainly confused.
Boiling Point/Range: 82°C (180°F)
Solubility in Water: Miscible
Vapor Density(Air=1): 2.1
AND MOST LIKELY:
Evaporation Rate(N-Butyl Acetate=1): 2.83
In response to your question regarding the flashpoint of a solution of 20% IPA, I am assuming that the IPA is either in water or fountain solution and it is by volume and not weight. In one study, a 20% concentration, the closed cup flashpoint was reported to be 87oF. Another study reported a flashpoint of 82oF. Neither of the studies reported what concentration of IPA would produce a closed cup flashpoint of 140oF. The lowest concentration tested was 5% by volume and both studies seem to agree 122.5 vs 123.8 oF. While it is not clear from your email why you are interested in this data, recognize that solutions containing less than 25% alcohol are not considered a hazardous waste due to the characteristic of ignitability (flashpoint < 140oF).
The conversation can be followed at
http://www.pneac.org/listserv/printech/0108/0108ask4.html
HAZOP at www.curryhydrocarbons.ca
IPA in water. Use this to calculate the concentration of IPA in the vapor above the liquid at various temperatures & compare to the LEL of IPA. The temperature at which the IPA vapor concentration equals the LEL is approximately the flash point.
