Excel crashes and Solidworks
I have been having a lot of trouble with both software packages.
I am running on Windows XP Professional Version 2002 Service Pack 1
SolidWorks 2003 SP3
Microsoft Excel 2002 SP-2
I don't know how to reproduce this problem, but it happens very frequently. When I start up Excel on its own it crashes. Asks me if I want to recover my work and send an error report. This happens continuously until I do on of the following:
The first one I found was to start a new SolidWorks file, insert a design table. Edit Table in New Window. Now I can open any existing Excel file. This also works by opening an existing SolidWorks file that has a design table.
The second way I found, by accident, was to open an older file, which happened to be a copy of a SolidWorks design table. After that Excel works fine.
Sometimes when working with Bills Of Material in SolidWorks drawings Excel will crash also.
Has anyone experienced anything similar? Any ideas?
SolidWorks 2003 SP3
RE: Excel crashes and Solidworks
The solution is to make sure you do not have Excel open in SolidWorks if you leave SolidWorks, if editing a BOM, close editing before leaving SolidWorks.
Are you trying to copy information from a file in Excel to an Excel file in SolidWorks?
Will Excel run if SolidWorks is closed?
Excel won't run on its own once the crashing cycle starts, I have to go through Solidworks to get it to run.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
From SWX website:
Design Tables or Bills of Materials and Office 97 SR-2:
If you are using Design Tables or Bills of Materials, we strongly recommend you install Microsoft Office 97 Service Release 2 (SR-2). Installing this Microsoft Office Service Release fixes a Microsoft problem that causes either or both Excel and SolidWorks processes to remain running when you exit SolidWorks.
It definitely sounds like there is something unclean about your Excel installation.
Here's a thought. Are you on a network? If so do you have Excel installed locally on your system (you should) or is it by network access (bad). Is your system trying to execute from both versions?
Thanks for the help.
Manually starting SW explorer, then shutting it down, then attempting to start SW from Excel can do much the same thing: instead of SW being started, SW explorer would be.
If you have the cursor in a cell of Excel either in a BOM or an Excel worksheet and try to move to the other window is where I have seen problems.
