Water lubricated journal bearing
Hi...i need some artical or journal on water lubricated journal brearing. I only manage to find some on oil lubricated bearing...Thanks for guildance..
Cheers,
Yutaini
RE: Water lubricated journal bearing
My first thought was the cutlass bearing on the prop shaft of inboard engine mounted boats.  I know they are made from a bronze shell with a rubber liner, but I can't give you anymore specifics.  My advice if you want to persue this is to contact a marina supply retailer and get a name of a cutlass bearing manufacturer.  Then give these people a call and discuss the materials and design.  Good Luck!
