Noise of steam through gate valve
Can anyone point me in the right direction? I need help in calculating the sound generated from saturated steam (~35 psig) passing through a gate valve and exiting to the atmosphere.
Thanks!!
jproj
Thanks!!
jproj
RE: Noise of steam through gate valve
There also is a section on valve noise in the Noise and Vibration Control Engineering: Principles and Applications by Beranek and Ver. It contains a simplified version of the above standard.
Hope this helps
Several of the valve companies (Fisher Rosemount, etc) have estimates to vent stack noise. Banerek also documents the noise estimate.
