Command line bar - Disappeared!
In AutoCAD LT the command line bar has dissapeared - not to be found!  I can press F2 to bring the command line up however I cannot dock it.  Please help.
Thankyou.
Paul
RE: Command line bar - Disappeared!
I work with AutoCAD 200x and newer saw AutoCAD LT. But its possible that your command line bar is accidently draged and dropped somewhere on your desktop. This draging and dropping leaves even you restart AutoCAD.
Try changing the screen resolution. The bar may be hiding off screen. Changing the resolution should pop it back on. Just change it back to what you want when finished.
