HEAD OR PRESSURE
HEAD OR PRESSURE
MAYBE A SILLY QUESTION:
IF THE REST OF THE PAREMETERS ARE KEPT CONSTANT, A CENTRIFUGAL PUMP GIVING 1O FEET WHEN PUMPING WATER, WHICH HEIGTH WILL GIVE WITH A FLUID OF A STANDARD GRAVITY OF 0.5?
IN OTHER WORDS DOES THE PUMP GIVE THE SAME HEAD (THEN THE RESPONSE WOULD BE 10 FEET OF THAT FLUID, THE PRESSURE WOULD BE HALF OF THE WATER CASE) OR THE SAME PRESSURE (THEN THE RESPONSE WOULD BE 20 FEET)
RE: HEAD OR PRESSURE
Remember, head is always unchanged (again, assuming non-viscous fluids) and pressure is a result of the specific gravity by the equation: PSI = TDH (in feet) * S. G. / 2.31
One of the asumptions with the Bernoulli equation is that you have a non-viscous fluid. When you are pumping crude oil or molasses, then the pump performance changes because now you have viscous forces acting on the impeller that reduce the kinetic energy and thus the kinetic energy/head trasnfer phenonema at the pump casing.
So, as long as you have enough motor and the fluid is like water, that same pump will still pump the new fluid to ten feet, but your power draw will be cut in half and so will the pressure.
Tim
tstead gives a good answer, above. However, for a more "official" (published) response, note that you can also refer to Question 4.25 from Karassik's Centrifugal Pump Clinic. Here, Karassik states that "for a given pump operating at a given speed and handling a definite volume, the energy applied to the fluids is the same for any fluid regardless of density. Therefore, we interpret this to mean that even though our test temperatures are different from the pump curve test temperature, we do not have to make corrections to enter the pump curves...".
Recall from your fluids textbook that pump head, expressed in units of length (feet), is really energy per unit weight of fluid. So, if the energy applied is constant, the TDH is constant (assuming inviscid fluids).
Just thought I'd pass some of this along. It's a seemingly simple question with an answer that may not be so straightforward for many (including me!).
What will change is the pressure at the pump discharge as does the power input, both change in accordance with the specific gravity of the product.
However, as already pointed out by others, if the liquor is viscous then a different set of rules apply.
Naresuan University
Phitsanulok
Thailand
PSI will change, dependent on SG. PSI = feet x SG / 2.31
