MS Common Dialog object in VB macros
Is there a way to use MicroSoft's Common Dialog object (for browsing and selecting files to open, etc.) within a VB macro?  I get a message that it is not licensed when I try to use it in a macro (works fine w/ straight-up VB).
I wrote a separate file selection form, but it can be slow.
Someday, someone may kill you with your own gun, but they should have to beat you to death with it because it is empty.
RE: MS Common Dialog object in VB macros
TheTick,
I got the same thing more than a year ago, so I gave up on it. I thought it was a "left over" from me deleting VB off my one machine, but it did the same thing on a different machine.
Mr. Pickles
No problem here, I'm using VB6 professional and can include the MS common dialog controls version 6 .0 without any problem.
But I usually use the Windows API commands to avoid problems with machines, where the common dialog control is not installed (which is rather unusual, but may happen).
Take a look at my "Save high resolution bitmap" macro at http://swtools.cad.de/macros.htm (the one called mm_18.zip). In the userform there is the code how to use the standard file-open-dialog with Windows API only (and without the need for the control).
HTH,
Stefan
unofficial german SolidWorks helppage
http://solidworks.cad.de
Shareware, freeware, tools and macros
It's not really a problem in a VB program that runs independently.  It seems to be a problem in VBA macros embedded in other programs.  It also occurs with macros embedded in Excel
Here is a module I drop into VBA projects for different Common Dialog windows. It is self-contained, and uses pure API calls to generate the dialogs. It has  "File Open,  "File Save", and  "Browse for Folder"  routines in it.
The "OpenFiles" routine accepts Multiple file select, and, unlike other VB versions, allows you to use a network/removeable etc drive to have appear when the dialog appears. Remember that the routine uses VARIANTS as a return, so NO file selected would return EMPTY.
I also patched the 'parent' hWND to point to the desktop, because it's such a pain in the arse to get the hwnd of Solidworks.
'----- cut here --------------------------------
Option Explicit
' use new call below to set network drives as curdir
Private Declare Function SetCurrentDirectoryA Lib "Kernel32" (ByVal lpszCurDir As String) As Long
Declare Function GetDesktopWindow Lib "user32" () As Long
Const OFN_ALLOWMULTISELECT = &H200
Const OFN_CREATEPROMPT = &H2000
Const OFN_ENABLEHOOK = &H20
Const OFN_ENABLETEMPLATE = &H40
Const OFN_ENABLETEMPLATEHANDLE = &H80
Const OFN_EXPLORER = &H80000
Const OFN_EXTENSIONDIFFERENT = &H400
Const OFN_FILEMUSTEXIST = &H1000
Const OFN_HIDEREADONLY = &H4
Const OFN_LONGNAMES = &H200000
Const OFN_NOCHANGEDIR = &H8
Const OFN_NODEREFERENCELINKS = &H100000
Const OFN_NOLONGNAMES = &H40000
Const OFN_NONETWORKBUTTON = &H20000
Const OFN_NOREADONLYRETURN = &H8000
Const OFN_NOTESTFILECREATE = &H10000
Const OFN_NOVALIDATE = &H100
Const OFN_OVERWRITEPROMPT = &H2
Const OFN_PATHMUSTEXIST = &H800
Const OFN_READONLY = &H1
Const OFN_SHAREAWARE = &H4000
Const OFN_SHAREFALLTHROUGH = 2
Const OFN_SHAREWARN = 0
Const OFN_SHARENOWARN = 1
Const OFN_SHOWHELP = &H10
Const OFS_MAXPATHNAME = 128
Const BIF_RETURNONLYFSDIRS = &H1
Const BIF_DONTGOBELOWDOMAIN = &H2
Const BIF_STATUSTEXT = &H4
Const BIF_RETURNFSANCESTORS = &H8
Const BIF_BROWSEFORCOMPUTER = &H1000
Const BIF_BROWSEFORPRINTER = &H2000
Const MAX_PATH = 260
Const OFS_FILE_OPEN_FLAGS = OFN_EXPLORER Or OFN_HIDEREADONLY Or OFN_LONGNAMES Or OFN_CREATEPROMPT Or OFN_NODEREFERENCELINKS
Const OFS_FILE_SAVE_FLAGS = OFN_EXPLORER Or OFN_LONGNAMES Or OFN_OVERWRITEPROMPT Or OFN_HIDEREADONLY
Const OFS_MULTIFILE_OPEN_FLAGS = OFN_ALLOWMULTISELECT Or OFN_HIDEREADONLY Or OFN_EXPLORER Or OFN_LONGNAMES Or OFN_CREATEPROMPT Or OFN_NODEREFERENCELINKS
 Type OPENFILENAME
    nStructSize As Long
    hwndOwner As Long
    hInstance As Long
    sFilter As String
    sCustomFilter As String
    nCustFilterSize As Long
    nFilterIndex As Long
    sFile As String
    nFileSize As Long
    sFileTitle As String
    nTitleSize As Long
    sInitDir As String
    sDlgTitle As String
    flags As Long
    nFileOffset As Integer
    nFileExt As Integer
    sDefFileExt As String
    nCustDataSize As Long
    fnHook As Long
    sTemplateName As String
End Type
 Type BROWSEINFO
    hOwner           As Long
    pidlRoot         As Long
    pszDisplayName   As String
    lpszTitle        As String
    ulFlags          As Long
    lpfn             As Long
    lParam           As Long
    iImage           As Long
End Type
Dim FileInfo As OPENFILENAME
Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
Declare Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long
Declare Function SHGetPathFromIDList Lib "shell32.dll" Alias "SHGetPathFromIDListA" (ByVal pidl As Long, ByVal pszPath As String) As Long
Declare Function SHBrowseForFolder Lib "shell32.dll" Alias "SHBrowseForFolderA" (lpBrowseInfo As BROWSEINFO) As Long
Declare Sub CoTaskMemFree Lib "ole32.dll" (ByVal pv As Long)
'  |             -= Main sub to call File SAVE Dialog =-                |
'  | Parameters: FileName$ is a variable that the name of the SAVED     |
'  |            file name is returned in. You do NOT have to pass       |
'  |            a filename to this routine, one is returned. Note       |
'  |            that the Win API checks for, and prompts, if the        |
'  |            filename already exists.                                |
'  |            FileExt$ is the file extension name you wish the        |
'  |            Dialog box to use, for default extension, file          |
'  |            listings, and availablity innthe drop-down "file        |
'  |            type" box.                                              |
'  |            FileDesc$ is a descriptive name for the File Name       |
'  |            Extension, used to describe the filetype in the drop    |
'  |            down type box.                                          |
Function SaveFile(FileName$, FileExt$, FileDesc$, WinTitle$) As String
    Dim strCurName As String
    Dim strFill, strFilter As String
    Dim lngReturn, ShortSize As Long
    On Error GoTo Err_Control
    strCurName = FileName$
    strFill = Chr(0)
    FileInfo.nStructSize = Len(FileInfo)
    FileInfo.hwndOwner = GetDesktopWindow
    'This section is for the filter drop down list
    strFilter = FileDesc$ & strFill & FileExt$ & strFill
    strFilter = strFilter & "All Files" & strFill & "*.*" & strFill & strFill
    FileInfo.sFilter = strFilter
    'This is the default information for the dialog
    FileInfo.sFile = FileName$ & Space$(1024) & strFill
    FileInfo.nFileSize = Len(FileInfo.sFile)
    FileInfo.sDefFileExt = FileExt$
    FileInfo.sFileTitle = Space(512)
    FileInfo.nTitleSize = Len(FileInfo.sFileTitle)
    FileInfo.sInitDir = CurDir
    FileInfo.sDlgTitle = WinTitle$
    ' use below to call save dialog
    FileInfo.flags = OFS_FILE_SAVE_FLAGS
    lngReturn = GetSaveFileName(FileInfo)
    If lngReturn Then
        SaveFile = FileInfo.sFile
    End If
    On Error GoTo 0
    Exit Function
Err_Control:
    'Just get out, to many things to account for
    MsgBox Err.Description, vbCritical, "Too many errors, aborting"
End Function
'  |                          -= OpenFiles =-                           |
'  | Parameters:FileExt is the file extension name you wish the         |
'  |            type" box.                                              |
'  |            FileDesc is a descriptive name for the File Name        |
'  |            WindowCaption is the string you wish to display         |
'  |            in the dialog title bar                                 |
'  |            AllowMulti is a boolean describing whether you wish to  |
'  |            allow multiple files to be selected                     |
'  |            StartDir Is a string describing the Folder name in      |
'  |            which you want the dialog to be displaying on open.     |
'  |  Returns:                                                          |
'  |            a variant safearray of the qualified filespec/pathspecs |
'  |            If user does not select anything, variant is EMPTY.     |
'  |            If user selects one file, it will be UBOUND(0)          |
Function OpenFiles(FileExt As String, FileDesc As String, WindowCaption As String, AllowMulti As Boolean, StartDir As String) As Variant
    ' filedesc=File description for drop down box
    ' WindowCaption = caption of the file window
    ' parent hwnd - usew dewsktophwnd?
    Dim lngReturn As Long
    Dim strFill As String
    Dim strFilter As String
    Dim CurrentDir As String
    Dim strReturnFiles As String
    Dim varReturnFiles As Variant
    strCurName = ""
    CurrentDir = CurDir ' store current directory
    If StartDir > "" Then
        SetCurDir StartDir ' set current directory to passed dir
    End If
    strFill = Chr(0)
    FileInfo.hwndOwner = GetDesktopWindow  ' return hwnd of desktop
    strFilter = FileDesc & strFill & FileExt & strFill
    FileInfo.sFile = strCurName & Space$(1024) & strFill
    FileInfo.sDlgTitle = WindowCaption
    ' use below to call open dialog
    ' optionally use single or multiple selection open flags
    If AllowMulti = True Then
        FileInfo.flags = OFS_MULTIFILE_OPEN_FLAGS
    Else
        FileInfo.flags = OFS_FILE_OPEN_FLAGS
    End If
    lngReturn = GetOpenFileName(FileInfo)
    ChDir CurrentDir    ' reset current directory
    If lngReturn Then       ' all went well, see if we have multi files to parse
        strReturnFiles = FileInfo.sFile
            varReturnFiles = SeedFileList(strReturnFiles)
        Else
            varReturnFiles = Array(strReturnFiles)
        End If
    Else
        Exit Function
    End If
    OpenFiles = varReturnFiles
    On Error GoTo 0
    Exit Function
Err_Control:
    Err.Clear
End Function
Function BrowseForFolder(WindowTitle As String) As String
' call the Browse for folders dialog,
' returns Pathname
    Dim bi As BROWSEINFO
    Dim pidl As Long
    Dim path As String
    Dim pos As Integer
    Dim pathRet As String
    Dim lastChar As String
    bi.hOwner = GetDesktopWindow ' get hwnd
    bi.pidlRoot = 0   'Pointer to the item identifier list
    bi.lpszTitle = WindowTitle   'message to be displayed in the Browse dialog
    bi.ulFlags = BIF_RETURNONLYFSDIRS   'the type of folder to return.
    pidl = SHBrowseForFolder(bi) 'show the browse for folders dialog
    path = Space$(MAX_PATH) 'parse the user's returned folder selection contained in pidl
    If SHGetPathFromIDList(ByVal pidl, ByVal path) Then
        pos = InStr(path, Chr$(0))
        pathRet = Left$(path, pos - 1)
        lastChar = Right$(pathRet, 1)
        If lastChar <> "/" And lastChar <> "\" Then pathRet = pathRet & "\"
        BrowseForFolder = pathRet
    End If
    Call CoTaskMemFree(pidl)
End Function
Function SetCurDir(NetPath As String) As Boolean
' uses API call to set CurDir for file open/save
' (VB only allows local dir for CurDir)
    Dim FName As String, CDir As String
    CDir = CurDir$
    SetCurDir = SetCurrentDirectoryA(NetPath)
End Function
Function SeedFileList(nullStr As String) As Variant
' processes return from "OpenFiles" routine, when multiple files are selected
' Win API returns a string embedded with many files,
' each terminated with an ascii zero. Takes this string and returns
' a varaint safearray of fully qualified Filespecs (or empty if none)
    Dim strLoc() As Integer
    Dim strCounter As Integer
    Dim FileCounter As Integer
    Dim FileSpec() As String
    Dim strLen%, I%, Char$, NextSeekStartPos%, SeekLength%
    Dim LastSeekPos%, NextSeekEndPos%, ThisStr$, FilePath$, SwapStr$
    If Len(nullStr) = 0 Then Exit Function
    strCounter = -1
    FileCounter = -1
    strLen% = Len(nullStr)
    For I% = 1 To strLen%
        Char$ = Mid$(nullStr, I%, 1)
        If Char$ = Chr$(0) Then
            strCounter = strCounter + 1
            ReDim Preserve strLoc(0 To strCounter) As Integer
            strLoc(strCounter) = I%
        End If
    Next I%
    ' now Loop thru and find where  2 ascii nulls are next to each other. thats where the string 'array'  ends
    If strCounter > 1 Then   ' if only 2, then only one string
        For I% = 0 To (strCounter - 1)
            If strLoc(I%) + 1 = strLoc(I% + 1) Then ' byte locations next to eacxh other
                strCounter = I%    ' end at the first of the 2 matching null sets
                Exit For
            End If
        Next I%
    Else
        strCounter = 0 ' set to 0-based "1" index
    End If
    ' Now that we've changed the counter, lets go back and get the strings
    LastSeekPos% = 0  ' initialize last found location
    For I% = 0 To strCounter
        NextSeekStartPos% = LastSeekPos% + 1
        NextSeekEndPos% = strLoc(I%) - 1
        SeekLength% = NextSeekEndPos% - NextSeekStartPos% + 1
        ThisStr$ = Mid$(nullStr, NextSeekStartPos%, SeekLength%)
        If I% = 0 Then ' if first entry
            If strCounter > 0 Then   ' and there is more than one file, then first entry is the path, dont add to list
                FilePath$ = ThisStr$
                If Right(FilePath$, 1) <> "\" Then FilePath$ = FilePath$ & "\"  ' append dir char
            Else   ' first of one entry; add it to the list
                FileCounter = FileCounter + 1
                ReDim Preserve FileSpec(0 To FileCounter) As String
                FileSpec(FileCounter) = ThisStr$
            End If
        Else     ' Second or Greater entry, PREpend pathspec
            ThisStr$ = FilePath$ & ThisStr$
        End If
        LastSeekPos% = strLoc(I%)
    Next I%
    ' Now build an output string (variant safearray), nulls removed
    If FileCounter > -1 Then
        If FileCounter > 0 Then ' reverse first and last entries (always comes back crooked!)
            SwapStr$ = FileSpec(FileCounter)
            FileSpec(FileCounter) = FileSpec(0)
            FileSpec(0) = SwapStr$
        End If
       SeedFileList = FileSpec()
    End If
End Function
' ----- cut here  ----------------------------
