custom hole callouts not working on mirror parts
When I detail (make a drawing of) a mirror part, the hole callouts somehow revert to the old hole callout definitions. My custom hole callout definition file works fine otherwise. Anyone else having this problem?
RE: custom hole callouts not working on mirror parts
Create a projection view from the view you are dimensioning, then project the new view again in the same direction, and try redimensioning.
Good lock.
