Custom note borders
Custom note borders
Custom note borders
Does anyone know of a way to make custom note borders? I am trying to make my life easier by using note borders instead of blocks (which don't work...another bug fix issue).
SolidWorks note borders include circular, triangle (only one version with the flat on bottom), hexagon, box, diamond etc.
How in the heck do I make my own borders?
Tim
RE: Custom note borders
Edit Sheet format and add text, lines, etc... once your done do a "Save as Sheet format" that saves your title block. Then you can reuse as needed. You just have to pick in from the dialog box you get when make a new drawing. "Custom sheet format" Or set it up in a special drawing template.
I hope that helps,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
You must have read my question wrong, I said "Custom NOTE borders".
Do you mean things like ballons that fit around a number of characters rather than a big box round the entire chunk of text?
