comparison between inconel and ferralium
We need to know the comparison between inconel and ferralium, because the existing valve material  is ferralium but the new material valve is inconel. Please advice us whether inconel can replace ferralium
RE: comparison between inconel and ferralium
you need to be more specific about the valve service.
ultimately the valve supplier has to warranty(or needs to be involved) with the materials selection.
Hi edfmm
You will need to look at your specific requirements because in many instances the properties of Inconel(600) are inferior to Ferralium(255) eg lower design stress, poorer resistance to erosion and abrasion.   However, if your Ferralium component was overdesigned you may find the Inconel more cost effective.....
