Insulation test on winding
Is there any one could advise me how often to check the motor winding insulation ?
Tanks
Yamin
Tanks
Yamin
Insulation test on windingInsulation test on winding(OP)
Tanks Yamin Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Insulation test on winding
if the motor is sized correctly to the driven load and is not over loaded or stressed in any way ie:-under or over volts,balanced supply or contaminated(build up of dirt reducing cooling form)then most motor manufacturers would recommend a full electrical test each bearing change. however should one of the above conditions change then your own discretion would apply. for high voltage machines a p.i. test should be done at least once a year on the motor windings as you would do a yearly maintanence.this is ofcourse depending what maintanence schedual you have in place.
hope this will help.
kind regds.
They are medium voltage motor 3.3kV and 400 Volts motor. Dusty enviromental, I think IEEE standard ???
The 400 v motor If its tefc then don't bother unless it has a problem.If it is open frame then say anually on your normal maintenance routine from the contactor when supply is isolated. Modify the frequency if you have a history of insulation failure. (after you have looked a why the failures).
The 3.3kv as per teco's recommendation
Regards Don
how critical is the motor? are there backup/spares available incase of unexpected failure? for example: sump pump motors might get meggered once every 3 - 5 years whereas the exact same motor used in a nuclear safety related application or Navy warship might get meggered twice a year. What is most important I think is the TREND. So you establish a base line megger value of the new motor or new winding if after a rewind. A brand new winding should be meggered before installation. Then after one year or two (next outage) repeat the megger and continue at this pace until you start noticing a downward trend, you would want to SCHDULE a refurbishment. After all, the only reason to perform preventive maintenance such as megger testing is to prevent that operational failure which could cost jobs; scrap the motor; and always seems to happen right before a holiday!
Yes I bow to your common sense statement. yes I was assuming those hack motors non critical etc etc I do megger our compressor motors etc every year because they are critical. One thing you did miss though -- the **** motors always go at 15 minutes to home time friday
regards Don
1. Visit
http://www.ieee.org
for more info on the IEEE Standards
2. Search of 1. above may reveal IEEE Standards:
112-1996
252-1995
841-1994
1068-1996
1107-1996
1290-1996
Inquire carefully about their content. It can be seen on the Web.
