Cog wheel, belt size design help
Hello all, I am new to this forum, and I have mostly a software background so mechanically, I'm a little lacking.  Anyhow, I have a stepper motor that steps 1.8 degrees/step and I need it to move a transport shuttle between 8 different positions 0.875" apart via a cog(timing?) wheel and belt system.  What I need to know is how do I determine the size of the wheels and belt.  I would like to keep the driver and idler pulley equal, but it's not necessary.  I guess what I'm looking for is a formula or algorithm (must be my software-minded thinking).  Any help would be appreciated.
RE: Cog wheel, belt size design help
HI TeknoFreek1284
Depends on how many steps do you want the motor to do between the different positions for example:-
  for 8 positions over 360 degrees = 45 degrees between each
                                     position
and that would equal 45/1.8 = 25 steps of your motor per
                              position.
so 0.875/25 = 0.035" per step
now to find radius of pulley "r"
     0.035= r * angular step of motor in radians
     0.035= r * 2* 3.142 * 1.8/360
     0.035*360/(2*1.8 * 3.142)=r
     r = 1.11394"  so 1.11394 * 2 = 2.22788 dia
so pitch circle dia for driver and driven = 2.22788" dia
regards desertfox
Yes, but the timing sheaves will most likely be specified as number of teeth instead of pitch diamter.  You will have to pick the closest available tooth count sheave and adjust number of steps between positions accordingly.
Mike
