Allowable Hydrotest stress
Can anyone tell how allowable hydrotest stress should be determined for flat heads or tubesheets?
RE: Allowable Hydrotest stress
not sure what you  are meaning..can you explain a bit more what you are looking for..AYBEE
Aybee,
Thank you for your response.
When you perform a hydrotest, you can't apply too high pressure because the stress developed may be excessive. My question is during hydrotest, how high stress can be allowed. On what rule, should the maximum allowable hydrotest stress for flat heads or tubesheets be determined?
kyong
ASME VIII Div.2 gives a limit of 90% of min.yield stress for general primary membrane stresses and of 135% of yield for primary membrane plus bending stresses.
prex
http://www.xcalcs.com
Online tools for structural design
prex,
Thank you very much.
kyong
The ASME codes(fired and unfired pressure vessels) will show you the formulae needed to calculate the MAWP's of these item you mentioned.  The hydrostatic test will be at 150% MAWP.
