Select All Objects On One Layer
I often want to select ALL objects on ONE layer (I am using AutoCAD LT 2000). Is there any way I can do this?
Thanks for your help.
Brian
Brian
RE: Select All Objects On One Layer
Filter is just what I needed.
Brian
Or here is an old routine that turns off everything but the selected layer. Only works on one layer.
defun C:LSF ()
prompt "\nPick object drawn on layer you wish to be new CURRENT LAYER ...")
setq LAY (cdr (assoc '8 (entget (car (entsel))))))
command "-layer" "S" LAY "off" "*" "N" "")
(defun C:LSF ()
(prompt "\nPick object drawn on layer you wish to be new CURRENT LAYER ...")
(setq LAY (cdr (assoc '8 (entget (car (entsel))))))
(command "-layer" "S" LAY "off" "*" "N" "")
