Looking for small form factor PC with 1 PCI slot
Does anyone know of a small form factor PC with 1 PCI slot that can be powered by 12 Volts?
RE: Looking for small form factor PC with 1 PCI slot
What do you want to use the one PCI slot for ? Standard or
custom card ?
<nbucska@pcperipherals.com>
The PCI slot is for a high resolution (24 bit) data acquisition card from National Instruments.
<www.bagotronix.com>; has a 2"x2.6" 188 based, PC compatible
DOS based computer but no PCI -- but I think it could be interfaced to your card.
Do you try to power a "normal" PC with a inverter?. So you can have a 12 VDC PC and use a automotive battery. Remove, if you want to use the PC for control, all the devices you dont need, for example, the sound card (your even can desconnect the monitor and have your PC working !)
