problem creating images with floworks
hi all!
i did some flow analysis using floworks and want to save the results just as normal bitmap-files. when i use higher resolution settings solidworks doesn`t display the numbers of the scale in a correct way. has anyone experienced the same problems?? my os is win2000.
thanx for any kind of hints
RE: problem creating images with floworks
Sounds like a graphics issue to me. What video card do you have? Have you downloaded the latest video driver from the Internet?
Also, are you using SolidWorks 2003 SP3.0? SolidWorks 2003 is very graphically intensive, which is good if you have a good video card, but not so good if you have a gaming card.
SP3.0 solves some of the graphics issues.
cheers,
Joseph
