Units in Mathcad
Units in Mathcad
Units in Mathcad
Does anyone know of a way or way around the unit calculations for anything that has to do with squareroot of f'c?
RE: Units in Mathcad
Under the radical multiply f`c by psi.  For example when calculating Ec for concrete I use the following:
     Ec := 57000*sqrt(f`c*psi)
This will give the proper units for use in subsequent
calculations ...
MLM
In the functions list (at least in Mathcad 11 I don't know about previous versions) there is a function called
UnitsOf() I had to use it for a function that was raised to a power of 2/3. It solves your problem but it makes the equations look bulky because you divide by it and it actually displays as "UnitsOf(X) in your worksheet.
Wish there was a better way.
DPA
