Variable Section Sweep
Hi
I want to cut around a solid base with variabe sections.I can do with constant section using command "cut-sweep".
can anyone help.
thanks.
omer
RE: Variable Section Sweep
You could try using a sweep with guide curves.  If you need to control the section at different points along a trajectory, use a loft.
Your terminology and previous posts suggest that you have experience with Pro/E.  You could compare use of guide curves in a sweep to Pro/E's "variable section sweep".  However, SW limits to two guide curves.
On justice and on friendship, there is no price, but there are established credit limits.
Can i cut in a base feature using loft command with variable sections.
thanks for replying.
Sure you can into the base feature using the loft command, I don't see why not.
You can't remove the entire base though, you have to leave something there.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
QUOTE:
<However, SW limits to two guide curves>
I am not aware of any such limitation.  ASFIK, you can have an unlimited number of guide curves for a sweep.  I just made one with 3 guide curves.
Sorry.  My surface game is a bit rusty.  Sweeps allow multiple guide curves, but for orientation control, one is restricted to using 1st or 2nd guide curves.
One thing I would like to see is a feature similar to Pro/E's variable section sweep.
Someday, someone may kill you with your own gun, but they should have to beat you to death with it because it is empty.
thanks buddies for all the help i will try it then let u know.
