Where can I get a copy of the document ANSI A10.5-1969?
I have been trying to get a copy of ANSI Standard ANSI A10.5-1969 for cranes & hoists. The ANSI website is not very helpful in obtaining this information. Does anyone know where I can obtain a copy of this document?
Nikkodesign
RE: Where can I get a copy of the document ANSI A10.5-1969?
Hi Nikkodesign (Mechanical)
I do not know where yhou can find ANSI Standard ANSI A10.5-1969 for cranes & hoists.
But the following may help you:
http://www.standard.no/standard/index.db2?id=2160&PHPSESSID=19b3270325d84d94602bc2d49ed74f14
You are here : Petroleum / NORSOK Standards / RL-Lifting Equipment /
Forum of Discusions
Questions? Send mail to: Committee chairman or Project manager
CURRENT AND VALID VERSIONS
     R-CR-002 Lifting equipment (Rev. 1, Jan. 1995)
     R-003 Lifting equipment operation (Rev. 1, Oct. 1997)
     R-003N Operasjon med Løfteutstyr (Rev. 1, Okt. 1997)
WORKING PROGRAMME
New standards:
None
Standards for revision:
     ..R-003 Lifting equipment operation (3 rd. quarter 2003)
R-CR-002 Lifting equipment Rev. 1, Jan. 1995
http://www.standard.no/standard/NORSOK_standards/2160/R-002-CR.pdf?PHPSESSID=7aeb46c7dbb136d56e468deee14aec97
This standard specify the basic requirement for the design, fabrication, testing and other relevant services of lifting equipment.
This standard is in compliance with requirements in harmonised CEN standards. If relevant CEN standards has not been issued the priority shall be FEM standard, ISO and relevant recognised standards.
If no particular requirements to the equipment are defined, the general parts and data sheet are considered to be sufficient.
Supplier's standard solution shall be used to an optimum extent, provided these solutions are not in conflict with the requirement herein.
Download standard
Leonard@thill.biz
www.thill.biz
Isthill,
Thank you for that information. Althought it is helpful, I specifically need to know how the ANSI A10.5-1969 safety code is stated and what it covers. I imagine the standards are very similar however the OSHA document CRANES AND DERRICKS - §1926.550 specifies the ANSI A10.5-1969 safety code and that is why I am looking for that specific document.
Thanks Again,
Nikkodesign
HI Nikkodesign (Mechanical)
Disclaimer:
Steel Valley Crane Service, Inc. does not assume any responsibility for the validity, accuracy, or applicability of any information presented on this web page or any other web pages to which, or from which, it links. The information presented is not be construed or interpreted in any way to be applicable to any particular situation, nor is it to be considered a substitute for consultation with engineers, consultants, experts, etc
http://members.aol.com/svc430/prof2/page4.html#Crane%20Overloads
Leonard@thill.biz
www.thill.biz
Thank You to both IRStuff & Isthill.
I have not yet had a chance to go through the website thoroughly but it does appear to be a much better location than I have found.
FYI: The need for this document is just for reference.
Nikkodesign
