Landscape Images
Landscape Images
When I insert landscape images into my ACAD 2000 drawings, then render, a dark shaded area can be seen around the images in the shape of the opacity map. The opacity area on the TGA file is black, and I am using the standard images included with Autocad.
What could it be?
Dan
What could it be?
Dan
RE: Landscape Images
If so I had a similar problem which I solved by simply disabling it...
Dan
