Water Tank Corrosion Allowance
Preliminary design of a water storage tank to be located in a coastal area of California (saltwater environment) using the Storage Tank data sheet provided by the API Std 650 requires corrosion allowance values. Can anyone tell me what appropriate values should be used (in inches) for roof, shell, bottom, and structurals, and what the basis is for determining such values?
RE: Water Tank Corrosion Allowance
If this tank is for storing sea water, the average corrsion rates would be in the order of 10 - 15 mpy (mils per year). Atmospheric corrosion (bare carboon steel) in a marine environment is about 25 - 20 mpy (Measure at Point Reyes CA @ 19.7 mpy over two years.)
It is always good to consider the use of internal epoxy linings and external paint systems for corrosion protection. Cathodic protection should also be considered.
