Dimension Names
Dimension Names
I used to know how to display these (make them show) but forgot. Help is no help and I am too embarrassed to ask my associates.
Help please.
Help please.
Jesus is THE life,
Leonard
RE: Dimension Names
Tools\Options\General\Show Dimension Names
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
RE: Dimension Names
Is there a way to use that information in a note or in the modified dimension? Such as displaying the depth of a Counterbore (making it a driven dimension).
Example: Ø.25 (insert C'bore depth symbol) d4 (this is the dimension name)
This is the method I used in other solidmodeling packages to make the C'bore depth driven. Is it possible to put an "&" before the d4 to make it driven or some other symbol to identify it as linked?
Thanks!
Jenster
RE: Dimension Names
You can change a dimension to a driven dimension in a sketch by going to the properties window and checking the "Driven" checkbox, and the dimension will be controlled by the feature.
RE: Dimension Names
Some recommended reading in the help files:
Read about equations and linked dimensions. These are two distinctly different ways to relate dimensions to one another. Also, learn about custom properties, and practice inserting dimension references and using them in annotations.
Also, an FAQ tip regarding dimension names in equations
http://www.eng-tips.com/faqs.cfm?spid=559&sfid=590
I'll be watching this thread if you have any questions.
RE: Dimension Names
Now if I go back and change my model, the dimensions change, while my formating of them stays constant.
Ray Reynolds
Senior Designer
Read: FAQ731-376
"Probable impossibilities are to be preferred to improbable possibilities."
RE: Dimension Names
Your idea works great for getting the dimensions into the notes. However, I can't seem to get the tolerance value (limits for example). In other words, only the nominal value goes into the text block. Do you know of a way to get the limits of the dimension to "go with" the dimension when you use your method? Thanks for the tips.
To TheTick:
Thanks for your thoughts on using custom properties. I will need to do a little more reading and investigating to understand this method. So far, I haven't been able to make a custom property with the dimension value I need. I'm familiar with using the link capability on customizing the sheet formats (sheet number, PDM values, drawing numbers etc). But, I can't seem to figure out how to make a custom property of a dimension (so far anyway).
Thanks for the help. I appreciate the great tips and techniques.
Jenster
RE: Dimension Names
Type in a "Name" you want to give your custom property.
In "Value" Click the dimension you want to use.
Click add when finsihed.
When in a note (In a drawing that shows the same part. Part must be inserted into drawing) click "Link to property". Pick the Down arrow and pick the Name that you made in the part. Your Dim will now show up in your note.
I hope that helps,
Scott Baugh, CSWP
FAQ731-376
RE: Dimension Names
Thanks for the good tips and questions. These were worth copying to a Word document and pribnt out for later ref in my SW file.
Jesus is THE life,
Leonard
RE: Dimension Names
Ray Reynolds
Senior Designer
Read: FAQ731-376
