Post tension beam & P/A
Can P/A in a post tensioned beam be affected (ie reduce) during stressing if the beam is located between two stiff concrete cores?
RE: Post tension beam & P/A
Yes, if the anchorage develops both cores (assuming these are elevator shafts or stairwells...
