Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...I have answered some questions and have gotten answers for my questions. Anywhere you can do this on one page helps tremendously..."
Geography
rowe (Structural)
1 May 03 15:33
falsework for cantilever portions of a bridge deck are typically supported by the exterior girder (steel or concrete).  North Carolina DOT allows bolt holes in a steel girder web, if done during initial fabrication.  This allows connecting a strut to the web that results in a force perpendicular to the web. The web is checked for deflection (out-of-plane) similar to a simple beam using an effective web width (along the centerline of the girder) to calculate Moment of Inertia (effective).  NCDOT uses an effective width of We=0.4*depth of web + 0.2*spacing of bolt, so I=We*(depth of web)^3/12.  I cannot find any references to confirm this effective width of the web.  Any ideas are welcome - thanks.
P.S. The bolt is left in place after the falsework is struck.
curvbridger (Civil/Environme)
8 May 03 16:15
Is this bolt near the top or the bottom of the web plate? I am used to seeing the top strut element attatched to the top flange and the bottom strut element resting (in compression) against the web near the bottom.
I haven't seen your effective width formula before, but I have a few comments:
1. The effective width shouldn't be greater than the cantilever support (bolt?) spacing.
2.  The effective width will vary somewhat with the web thickness.  That is, a thicker web will distribute point loads better than a very thin one.
3.  Have you checked Roarke's formulas for this case??(infinite width thin plate with point load)
Additionally, wouldn't the I=We*(web thickness)^3/12??
rowe (Structural)
9 May 03 8:49
Curvbridger,
Thanks for your response.
We is based upon "depth" of web. I=We*(web "thickness")^3/12 is correct.
There are two main members in the support.  The top, horizontal member of the falsework is bolted to the web approx. 15" below the top flange.  The diagonal bears against the web and bottom flange.
Your second point is also valid.
I'll check Roarke's later when I can spend some time, and perhaps I'll revisit this thread.
Thanks again.
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Bridge engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=607
DESCRIPTION: Bridge engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
