Galvaneal Thickness: minimum
We are currently using a galvaneal product that is us weld quality issues...ie: porosity, lack of fussion.
The above mentioned material is domestically manufactured. We are also using an import material for a similar product. This material provides no weld issues.
We have been told that no one in the United States can produce this material coating @ 45grams/m squared with complete coverage.
Can anyone confirm this, or...if you no of a manufacturer, could you please provide me with the contact.
RE: Galvaneal Thickness: minimum
The hot dip process used to form a galvanised and subsequent galvanneal coatings are subject to errors in coating weight.  We can purchase both locally (not USA) and from Japan galvanneal to a guaranteed coating weight of 45gm/m2 minimum so I am sure it would be available in the USA too.  Try changing your supplier.
Thanks for the information and the reply.
Guys - Iused to work in the sheet steel industry dealing almost exclusively with low carbon DDQ- and HSLA steels - the galvanneal that you buy may not be the same as what you recieve if you know what I mean.. You might want to institute a requirement for outside A2LA testing of coating weight, chemistry so that you can be assured of the steel you buy.
nick
I'm not sure how I missed this thread originally, but one of the issues with a coating weight of 45 g/m2 is that it is not a standard one in the US.  ASTM A 653 is the standard in the US for this type of product and the standard weights are A40 or A50.  US Steel or Bethlehem would be the two suppliers I recommend for discussing availability, tolerances, etc.:
http://www.ussteel.com/corp/sheet/coated/nealapp.htm
https://e-commerce.bethsteel.com/App/PrdApp/Products/pgGalvannealOverview?pgGalvannealOverview.Href_GalvannealClass=&pageAttributes=
