Tank Pressure Change
Is the process in a gas baldder accumulator isotropic, so that P1*V1=P2*V2?
RE: Tank Pressure Change
The perfect gas equation you quoted is actually for Isothermal, meaning no temperature change. Let me demonstrate:
(P1*V1/T1) = (P2*V2/T2); the full perfect gas equation.
If temperature is constant (i.e. Isothermal), then T1 = T2 so both T1 and T2 can be removed from the equation to leave:
P1*V1 = P2*V2 (which is what you've got).
As long as the changes are happening slowly, leaving plenty of time for heat transfer (which I would suggest is the case), then you have Isothermal processes, in which case you can indeed use your equation.
Hope this helps.
Brian
To be more general, instead of using P1*V1 = P2*V2 (as for your isothermal case), lets assume the correct relationship is P1*(V1^n) = P2*(V2^n). If the process is isothermal, then n = 1; if it is adiabatic (a more practical / likely version of the very ideal isentropic), then n = 1.4.
Do the sums yourself; they should agree with mine thus:
Isothermal case: pressure increases by about 15%, volume decreases to about 87%.
Adiabatic case: pressure increases by about 15%, volume decreases to about 90% (the volume has not decreased so much because no heat transfer means the air's temperature has increased under compression, so it exerts a higher pressure at each volume than it otherwise would have done).
For my money, there's very little difference; what do you think?
Brian
I suppose I'd have to determine exactly how critical estimating the volume will be. My guess is that it's not extremely vital in my case. Running my simulation for either case, I haven't noticed very much difference between the two cases, so that seems more or less in line with those results.
Thanks for the help.
I assume my conditions to be adiabatic.
Thanks in advance for your advice.
Tom
