I need video of the construction process for drilled shafts.
I would like to have as a reference some video (preferably downloadable) of the construction process for drilled shafts. If there is anybody out there that knows of anything could you please point me in the right direction. The video doesn't have to be a step-by-step procedure, a simple home video would be fine. Thanks
RE: I need video of the construction process for drilled shafts.
www.adsc-iafd.com
They should be able to help you.
