Choices in Software for Stress Analysis??
My only experience with Pro/E was using Ansys. What are the preferred software packages for performing stress analysis when using Pro/E??
Thanks!
Thanks!
RE: Choices in Software for Stress Analysis??
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
What about importing Pro/E files in FEMAP?
if you are intrested try the hypermesh tool for importing the pro/e files and do the preprocessing.for post processing you can choose either ansys/nastran...,this is only an suggestion.
regards,
prakash
Cosmos does not understand, the file created is a GFM format file so you need to rename the file to a *.gfm filename. The Pro/FEM module and Cosmos technique is extremely stable and fast and I have been using this for 5 years now. Pro/FEM can also export to othe FEA systems such as Ansys, Nastran, Patran, Supertab etc. Pro/FEM can also run your preferred solver from within Pro/FEM either online or in the background but I have never used this option. Hope this helps.
