text rotated appearance well plot wrong
Hi there,
I 've a tricky question :
In Autocad 2000, using a non world UCS (rotated axis z 193 Degree), i created some text (horizontal in this UCS). When I jump on the layout, create a viewport, the text look fine (horizontal) but on the preview (and plot) it appear rotated (very settled, 1 degree).
In the same viewport if i put the ucs back to world and get the view from the ucs world (command: plan, current ucs) the text appear rotated (193 degree)and print with this SAME angle (193 degree).
How I could fix it without changing my ucs and having to rotate my all drawing ?
In advance Thank you..
RE: text rotated appearance well plot wrong
Hi their..
This sounds like something I came across with LDD.
Are you using Land Developement Desktop?
Hi Cadqueen,
No I'm not using Land developpement Desktop...
Is it a Soft from Autodesk ? Did you solve this prob ?
YYYYYYYeeeeeesssssss
Wonderfulllll
Truly amazing.... As We say in my country :
B R A V O  !!!
Thank you so much !
LAND DEVELOPEMENT / CIVIL DESIGN and the SURVEY modules sits on top of AutoCAD.add on programs
It is a survey/civil persons dream come true.
It basically will draw everything for you from a point file!
go to www.autodesk.com for the descrption of these software.
They are AWESOME!
And yes I did resolve it it was a setting in my LDD.
