UL Design # X790
UL Design # X790
Trying to find an answer on this one.... Working on a set of shop drawings, and the architecturals spec UL X790 for fireproofing. We don't have that info here. Is there any way someone could pass along the thickness of fireproofing for a 3 hr rating, for a 14"x14"x3/8" square steel tube?
No liabilites or anything to worry about, just trying to size an aluminum column cover with assembly tolerance for the fireproofing.
Thank you much for your time.
