hand spanners lenght standards
The length of standard spanners is determined to develop a tension to the bolt of according to:
ASME B31-3 S= 45000/Vd, with s = bolt tension and Vd= square root of bolt diam.
EN 1591 FBoav = AB x 1000/ VdBO, with FBoav = bolt force VdBO square root of bolt diam.
AB = effective bolt section
Are there different lengths of hand spanners on the market for different bolt material classes, for Anglo-Saxon as well as European standards. Certainly European bolts have huge differences in material strengths: 3.6 to 12.9. (300N/mm² to 1200N/mm²)
If there are differences in lengths of the hand spanners for different bolt strengths, according to what standards are the made. Is there any corrolation?
Please help
Raymond
Please help
Raymond
RE: hand spanners lenght standards
A 6" long wrench 'can' give identical torque readings as a 12" long wrench---just need more 'umph' on the end of it.
Rod
If you need more torque than you can apply by hand (to crack free that stubborn, half-rusted nut), a soft hammer will usually do the trick. Good quality spanners will handle this treatment well.
Pekelder
